Erik Kostson
Hi
Not sure we follow. If this is a 2 way FSI which it sounds like it is, then one can use system coupling between Fluent and Transient structural (see and search on the internet for video and tutorial on this as we do not have that here – since it is advanced).
Perhaps also this helps – if you have a frequency dependent pressure load from Fluent in a .cgns format then we can import this onto a surf154 element attached to a structure using the FLUREAD MAPDL command.
All the best
Erik
