Maira Perez
I am  having some troubles with to run this simulation. When the generation rate data is disable I can run my simulation of forward and reverse bias with the following warning
Then when the generation rate data in enable (under illumination simulation) I get a convergence error. I have tried to folllow the suggestion from : Convergence issues in CHARGE with no sucess
Then I tried to increase the auto- refinement and I played around with the global mesh constraint. However,i am still now managin to get my simulation converge under illumination.
I would appreaciate some insigth and help.
Error from log file
Current CHARGE settings
Changing gradient mixing for the other options was also tried.
