The top mesh looks to the better one. The boundary between fluid regions should be an interior in Fluent, and flow will pass straight through them. A wall is (generally) non-permeable and is used to stop flow but (generally) allow heat transfer. I think you may want to go through the geometry, meshing and solver tutorials to see how the process works.
