Sahil Sura
Hello, jmoss,
Hardness in FEA is very rarely used for the cases as the calculates rarely take hardness into account while calculating the results.
Hardness is also a property in general that has different scales to measure and also does not have a perfect definition (It can be relatively defined by various methods and in different scales.)
Thus if you want to calculate the hardness of the default material, you might want to simulate the deformation with the standardized hardness test. The predefined material properties would be sufficient enough to get accurate deformation results required for further calculations if proper mesh and boundary conditions are defined.
Hope this helps!
Thanks,
Sahil
