George Karnos
If you open a DOS Command prompt and type in the following:
ping servername
(where servername is the hostname of the license server)
Do you get a reply?
Is it the correct IPADDRESS?
Have you tried adding the ip address and hostname to the hosts file on your machine?
c:\Windows\system32\drivers\etc\hosts
Also:
Please open a CMD and run these three commands:
powershell -Command "Test-NetConnection servername -Port 1055"
powershell -Command "Test-NetConnection servername -Port 1056"
powershell -Command "Test-NetConnection servername -Port 2325"
Share the outputs.
note: I am looking for "TcpTestSucceeded : True" for each port.
