I recommend using DesignModeler for parameterization. It is more robust than SpaceClaim because DM is a history based modeler. That means you can always repeat the shape for a given set of inputs.  SpaceClaim has no history so a feature can be consumed during the excursion to one set of values and then that feature is not present when the initial set of values are used again.
