Heitor Facuri Cicoti
Hello, Peter and krsowpp.
This discussion was spot on for my problem. Thanks for that!
But there aren't any files attached, so I'm not sure what the solution was exactly, and how I could implement it in my case.
The STEP export/import does improve the precision indeed. Unfortunately I need the direct SC to Mechanical link, because I'm running 1175 design points with parametrized geometry.
I'm running a 3D simulation on a quarter of an oval ring, created with an ellipse line in the sketch. So, in my case, an array of 88 surfaces intersecting the part would be the solution? Or maybe create the array of lines before extruding (pulling)?
Thanks in advance!
