DrAmine
You said that the temperature field is looking fine. If yes then I expect that it is a post-processing issue. Did you change the reference temperature value under Reference Values and set it to your inle temperature or the reference value you have in mind?  Generally the value be like q (100 W/m²) / (Twall-Tinlet( 20°C)))
