Andreas Koutras
There are various ways to apply load that are described in the LS-DYNA Manual Vol I. The commonly used keywords are:
*LOAD_NODE (applies load at nodes)
*LOAD_BODY (applies body loads, such as weight due to the acceleration of gravity)
*LOAD_SEGMENT (applies distributed load over a surface defined by segments)
*LOAD_RIGID_BODY (applies load at the center of mass of a rigid body)
