Sarvesh Rathi
Also, what does step control mean? Does increasing the number of steps lead to more bending.
Should I use steps as initial and minimum time step: 100 and maximum time steps 200
or should i use time as mentioned above.
Because I have seen that varying this setting leads to an output which leads to no bending sometimes.
Kindly clarify. It would be a huge help if someone could contact me at sr6090@nyu.edu or 3474715977 to solve and clarify the issue.
Thanks.
