Erik Kostson
Never use miicroplane, but perhaps this helps:
See the help manual for dmac – it is an element output it says in a section.
Also perhaps we need to set the result set, with say set command (set,last,last for last results)
See also if this helps
https://forum.ansys.com/forums/topic/microplane-concrete-output-results/
ALso the commands should be like these - see the help manual for more info on these:
/post1
set,last,last
/SHOW,png
esel,s,ename,,215
/view,1,1,1,1
plnsol,mpla,dmac
/show,close
In apdl it will show (.png) in the working directory, and i apdl in the mechanical window under the command snippet as an image
