Mathilde31
I have exactly the same problem with model reduction using Workbench (error: No MASTER degrees of freedom are specified.  If the TOTAL command was used for automatic generation of MASTER degrees of freedom, it is invalid with the SPARSE solver in a substructure analysis.  Please use  the M command to define at least one MASTER degree of freedom.).
Someone managed to find a solution ?
