When you changed some of the labels it sounds like something got scrambled. Do you have any non-conformal interface zones or walls with shell conduction switched on?  If you are reloading a mesh it suggests you're in Workbench. If you use Fluent standalone you can read a new mesh onto an existing case, but that's your decision, if the set up is fairly easy start from scratch.
