Christiantyo Moeprodjo
I will make sure to input this boundary condition!
Coming back to the heat transfer rate issue, is my method of extracting the Total Heat Transfer Rate accurate enough?
I have been reading this forum thread https://forum.ansys.com/forums/topic/calculating-heat-transfer-rate-in-fluid-cross-section-regions/ where a suggestion of using iso-surfaces was brought up, but I never knew how to get this to work in Fluent. Would this be applicable to my application, and if so how should I go about implementing this in my model? Are there perhaps any other alternative methods of extracting the heat transfer rate?
