Sarvesh Rathi
Thank you for help Ashish.
I already requested a support call through a same link a while back but did not get any response. Nonetheless, I have again requested the mail now. Kindly update if you got the request.
I also tried calling the support, but there is no technical support or operator connected. Kindly suggest if there is any direct number i can connect with.
I have defined mesh as non linear quadratic mechanical with face sizing method meshing of element size 1.e-3 m. Is this fine? or should I have a finer mesh?
Kindly note that I have already defined the timesteps. Doesnt the settings as mentioned in the above screenshot define this properly. If not how to define timesteps for each step??
