Rahul M K
By default, Ansys Fluent reports the value of the last iteration (Average Over set to 1), due to which you may notice slightly different values based on the number of iterations completed.
You are correct about the process. Specifying the Average Over (iterations) value greater than 1 will report the value averaged over the last N iterations specified.
For more info, refer Fluent User Guide 44.2.43. Force Report Definition Dialog Box (ansys.com)
If you are unable to access the link, follow this Forum discussion Using Help with links (ansys.com)
Hope this helps!
Rahul M K
