amkum
Thanks for your reply.
Are you suggesting using RGP table to give the saturation pressure in the cavitation model?
RGP Table: Lookup in saturation property tables for mass transfer exceeded the lower range 56197 times. Is this treated as error? To generate saturation table, I use the maximum and min pressure value from the previous study of same case. What is the right method to accurately generate this table?
For thermal phase change model, I used the ranz-marshall.
