Didar Mei
Dear Mr. Ashish Khemka,
Thank you for your reply. I turned on the large deflection. Below, I attached material models from engineering data. I used 3 materials, posmac 4 for the column, posmac 10 for the ribs and base, and stainless steel for bolts and nuts. Moreover, I attached a load-displacement curve that compares experimental and numerical results.
Best regards,
Didar Meiramov
