RSM: read the documentation to understand the limitations of 2-equation models in high swirl. Read the various threads on cyclones: they'll give you further advice on what's needed.
OK, are you working with Student, Research or Commercial licences? The former are for learning, so confidential work is against the terms, the latter means you should have access to direct support.
