johnstn
Hi Erik
Thank you for your answer. It works. However, I get the "(A...)" in the name.
Is it possible to get the name of the current analysis (based on the selected results)?
I would like to run a script for each container, not changing the [0] in the code. The script should read each result selected in "Solution" and export to an xls file.
Thanks again
