javat33489
I am writing it here. So that if someone has such a problem, they can solve it. Let's solve it together.
Noticed this feature. If I set the outlet pressure and the place where the vacuum will suck out the liquid. Then there is no negative pressure in the center, the pressure is simply less.
What do you think about this?
