Sean Harvey
Hello Sarvesh,
I think this is process, at least getting further than before. So with time=.94 and if end time is 1.0 you have 94% of the pressure applied. Can you highlight the loading on the model?  Where is the pressure applied?  Also, can you highlight where you have contact in the model. Also double check the material assignment is correct under the parts in geometry.  Just in case it was not.  I don't think this is the issue but just a basic check. Thanks.
Btw,  does the curve fitting match the material test data? Can you share plots of the fits and which hyper elastic material model you are using.
Sean
