Rahul Mule
it is recommended that you build up to the final two-way analysis incrementally, progressively adding complexity with each step. Check if your participant solutions works fine with representative loads. Look at the transcript files for errors if any.
Please refer Building a Coupled FSI Analysis from Decoupled Participant Problems (ansys.com).
