That's an old style polar mesh, we've not used those since Fluent 4. For Fluent Meshing use polyhedral or poly-hexcore; for Ansys Meshing sweep is probably the best option depending on the shape.
If you look in the post processing you'll see axial, tangential and radial velocity coordinates, these are relative to the fluid (cell zone) axis.
