Sahil Sura
Hi charles delepelaire,
You might want to use the 'Blocks recording' feature in SpaceClaim.
You can click on the 'Blocks' tool from the design tab to record the operations while performing.
And do add the dimensions accordingly. Say, for example, I create a rectangle and add two dimensions. D1 and D2 appear on the block recording window as we finish the operation.
You can also parameterize the dimensions by clicking the 'P' option beside the respective dimension.
For more information, the following references might be useful.
1. Recording Blocks (ansys.com)
Hope this helps!
Thanks,
Sahil
How to access the ANSYS Online Help
