Haiquan
Hello Sean
Thank you very much for your detailed explanations.
I use following workflow to input the mesh file and fiber orientation tensor file which are obtained from Moldflow simulation for the short fiber reinforced plastics. My simulation used solid elements with ANSYS 2021 R1
Question: Is the X axis normal stress parallel to main fiber direction in the element for such case of short fiber reinforced plastics?
Thank you in advance
