javat33489
Yes, that is right!
Isn't that enough?
Then such a question. After Eigenvalue Buckling, I do a dashed non-linear calculation using the solution from Eigenvalue Buckling. I set the load force*multiplier, i.e. 1,700.8 N. In this case, the structure used is already deformed from the previous solution. But when tested, it does not lose stability. Why?
