Guilin Sun
for each voltage, you will need to defind a material with the caluclated (n,k).
Only the data from CHARGE that can be defined as a function of voltage through np attribute, which is a perturbation to the base material.  However currently this attribute does not have anisotropy feature. So you will need to create the material at each voltage.
