Hi, I have the same issue. When I press calculate it just stays at 0% and never proceeds. I does not give me any error message and if I perform check case, all is good it says.
I want to perform a transient calculation. The last message is updating solution at tim levl N...done. then nothing.
At the end I have to forcefully shut-down fluent because it gets stuck without even starting
