Do you have "wrapper" defined in your job script before mpirun command? If wrapper is not connecting back to ls-opt, the job scheduler will try internal qstat command to get job status. This is just a fail safe check and this command may not work for all environements. Please check if wrapper is defined correctly in the job scrpt.
