Mike Rife
Strain energy is a typical result available.  If you want strain energy density then in the Details of the Analysis Settings; Output Controls make sure that Nonlinear Data is set to Yes.  Solve.  Then use a user defined result with the expression NLELWK (Non Linear ELastic WorK).
