No, it's not like that. Water enters through the nozzle into the pump chamber - then the water from the pump chamber goes outside into the tank under atmospheric pressure. I did not put pressure on the nozzle, only on the inlet to the pump and the outlet from the pump chamber, and after the nozzle into the pump chamber, the program calculates itself.
