TurboGrid can only mesh one blade passage/stage at a time. You will need to split the profile.curve file into separate files for each stage. Then you can generate a mesh for each stage. You will need to set the inlet passage interface of the second stage to the same position as the outlet passage interface of the first stage.
Hope this helps to solve your quiry.
Thank you!
