Use Edge Sizing with Bias to get an orthogonal element shape. Zoom in and manually measure the distance between nodes in the first layer and adjuat the Edge Sizing/Bias until you get the desired first layer thickness.
New Post - Reply To: How to achieve square mesh using inflation on 2 perpendicular edges?
