November 30, 2022 at 10:31 pm
Material is air, Out flow is used because i do not have an idea about the pressure at the exit. My question is in coupled solver how the pressure is calculated when mass flow is given at inlet or velocity inlet boundary is specified ? . Do you think pressure outlet will correct the result? Is it necessary to specify inlet supersonic gauge pressure? Then how to caculate the pressure if i give operating pressure 0Pa.
