December 1, 2022 at 12:11 pm
Even if I do so it is the same case with respect to updation time. The slices which I do for hexahedral meshing will be on the higher side and the named selections created will also be on the higher side. The requirement is such that I have to mesh individual compoenents in individual mechanical cells so that my colleagues can use them in their models. My question is when the entire problem can get solved in 5-6 hours (offcourse in my powerfull machine), this transfer of model from the "mechanical model" to a physics cell (Static Structural) itself is taking more than 5-6 hours which is quite disappointing, as I have to wait for 6 hours for a small geometry change which I would be doing in any of the cells.
