December 1, 2022 at 3:09 pm
Thank you for the reply. My expressions were singled value scalars. I actually used the example from the manual to test if the problem came from my side. However, this did not work either. I kept having the same standard Observables display window. I have also tested with the TUI and the expression is still not available. Is there anything that I need to activate to have access to the expressions on the adjoint solver?
