If you scale the domain in Fluent you can stretch/compress the mesh. However that can cause problems with the cell quality. If you do scale the domain having run a model you can continue to iterate, that will use the previous solution as a starting point. You can't just scale the model and expect the solver to recompute the solution without running.
