If the non conformal isn't defined you'll have a wall at that location, that may or may not cause something interesting to happen.
ICEM CFD isn't used as much now, and we're seeing good results with the poly meshes from Fluent Meshing. That removes the need to do the blocking, and also tends to give a signifcantly higher quality mesh than automatic blocking.
