The SIGFPE signal is raised when a computational error occurs. FPE stands for floating point exception. This could be some issue with the UDF you have defined (as per policy we cannot debug the code) or simualtion set up. I would recommend you try running simualtion without UDF and see if the issue persists. Please also check your mesh quality.
