December 3, 2022 at 5:46 pm
In Workbench, create a Modal analysis and use Fixed Supports for the connection of the structure to ground.
Then drag a Response Spectrum analysis and drop it on the Solution cell of the Modal analysis. You can then use the Input Spectrum in this analysis as a Base Excitation.
Take some courses to learn Modal Analysis and other Dynamic Analyses such as Response Spectrum.
https://courses.ansys.com/index.php/courses/modal-analysis-in-ansys-mechanical/
