Following up, I was able to get it to successfully load into ICEM if I saved it as simply .cas and not .cas.h5. For some reason the .cas.gz files were not loading. Thank you for the help Rob.
New Post - Reply To: Exporting 2D Mesh File from .cas.h5 file
