December 6, 2022 at 4:11 am
Hello Peter,
I am trying to create delamination on a composite blade. This blade is surface geometry and is assembled with many parts but the considered section is the top surface (I want to create the delamination on this part).
I am confused as below;
- To create delamination, the blade geometry should be solid elements.
- The geometry imported to ACP should be the surface type but the ACP can generate to solid element by the "solid model" command. So I don't know how to create delamination after setting parameters in ACP
- I assign the composite stack in ACP (e.g. 0/90/90/0). If I want to create delaminate between 0 and 90. How can I do it?
Could you please suggest me how to create delamination on the composite blade (curve surface)?
Thank you in advance
Panida
