Hello balias,
For add on information:
When Use Adaptive Sizing is set to Yes, the mesher uses the value of the element size property to determine a starting point for the mesh size. The value of the element size property can be set by the user or automatically computed using set defaults.
When you set it no, you will get couple of new controls like capture curvature/ capture proximity to control your mesh (Uniform, Curvature, Proximity, or Proximity and Curvature Sizing (ansys.com)).
Thanks
