Hello marhark92,
Just for add on information to what Vinayak has mentioed,
If you try to change in workbench then click on ” Display values in project units” to make this change applicable in project.
If you are trying to change in mechanical then at your bottom taskbar you can easily locate drop down list to change units. If it’s not appearing then please reset the layout.
Thanks
