RM
*PoorIntersectionThreshold (setting) defines the threshold at which the system coupling stops if the intersection between the coupling interfaces is low. In that case, improve the mapping by adjusting the interfaces or if you wants to continue with that disable intersection check with setting *StopIfPoorIntersection (setting).
Please refer MappingControl (singleton) (ansys.com) for more information.
