It can mean you have a folded surface, but it's also possible the surface mesh is chewing up the geometry. Some images of what you're trying to mesh will help. Otherwise, if meshing is sucessful look for very skew cells.
New Post - Reply To: Warning in Fluent meshing: The regions may not be computed correctly
