December 6, 2022 at 2:22 pm
Hi again Erik and other Ansys users,
Here I have attached the APDL code along with the geometry file with anf format.
If you run the code as it is and check the result for SMAX failure criteria, the maximum value is 1.03. Then read the run.dat for the second time,or use the RE-RUN button, and check the SMAX value which is 0.85 again! You can also check other results such as X-component of displacement.
Please let me know if you need more information or clarification.
