Mesh size is approx. 35 million cells and tip speed based on TS=pi∗D∗RPM/60 = ~665 m/s
I have not much idea how reverse flow behaves, but it looks like the higher the speed, the more reverse flow I am getting at boundaries inlet & outlet, which is also physical. Worth to mention: I am using an exp function for viscosity dependent on temperature
