Using more cells will cost compute and time, yes, but without running a finer mesh you won't know if the results are mesh dependent.
Accuracy is likely reason for mass loss. Whether that's convergence, cell resolution or solver related is a different question, and you'd need to run more models to change solver mesh & parameters to figure that out.
